How to Rip and Convert 2D DVD to 3D FLV?
09/09/2022
Same as Blu-ray, DVDFab 12 does not support to convert any DVD movies into 3D FLV format any longer due to the limitation of FLV itself. So, please select other video formats which can hold HD contents, like MP4, or MKV, etc. DVDFab DVD Ripper is a born DVDFab 2D to 3D Converter which works with DVD Ripper convert 2D DVDs into a range of 3D videos with very impressive 3D effects.
This tip below serves as a guide for you to do that:
2D DVD to 3D Video Converting > Step 1: Download and install the latest DVDFab 12 onto your computer;
2D DVD to 3D Video Converting > Step 2: Launch DVDFab 12, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the regular DVD you are about to convert;
2D DVD to 3D Video Converting > Step 3: Click the down-triangle button and click "Choose Other Profile", open profile library on the top left corner of the main interface and go to Format to choose a video profile from the "Format">"Video">"3D" column, according to what video format your 3D device is able to play back;
2D DVD to 3D Video Converting > Step 4: Click “Advanced Settings” button behind the Profile Box to do corresponding settings regarding to video, audio, subtitle and 3D formats;
2D DVD to 3D Video Converting > Step 5: Click the “Video Edit” button to customize the resulting 3D video if needed.
Software you need: The latest build of DVDFab 12
Product you need order: DVD Ripper
For more info, please go to: https://www.dvdfab.cn/dvd-ripper.htm?trackid=headmenu2,navmenu2
